주요 콘텐츠로 건너뛰기
Craig CMP801 Front and Rear Facing Camera Replacement
필요한 것
  1. Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Front and Rear Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Craig CMP801 Front and Rear Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Front and Rear Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Craig CMP801 Front and Rear Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 4 단계, 이미지 2개 중 1개 Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 4 단계, 이미지 2개 중 2개
    • Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
  5. Craig CMP801 Front and Rear Facing Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Near the edge of the device, lift up the tab connected to the front-facing camera.
  6. Craig CMP801 Front and Rear Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 Craig CMP801 Front and Rear Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the black flap that covers and holds down the tab connected to the rear-facing camera.
    • Flip the flap up to release the tab.
  7. Craig CMP801 Front and Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 Craig CMP801 Front and Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pull on the tab connected to the front-facing camera to release both the front and rear-facing cameras.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Erin
회원 가입일: 09/25/17
120 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 21
전체 시간: 377
