주요 콘텐츠로 건너뛰기
Craig CMP801 LCD Screen Replacement
필요한 것
  1. Craig CMP801 LCD Screen Replacement, Back Cover: 1 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement, Back Cover: 1 단계, 이미지 2/2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 LCD Screen Replacement: 2 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 LCD Screen Replacement: 3 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 LCD Screen Replacement, Volume Controls: 4 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement, Volume Controls: 4 단계, 이미지 2/2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 LCD Screen Replacement: 5 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 LCD Screen Replacement: 6 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
  7. Craig CMP801 LCD Screen Replacement, Battery: 7 단계, 이미지 1/3 Craig CMP801 LCD Screen Replacement, Battery: 7 단계, 이미지 2/3 Craig CMP801 LCD Screen Replacement, Battery: 7 단계, 이미지 3/3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  8. Craig CMP801 LCD Screen Replacement: 8 단계, 이미지 1/3 Craig CMP801 LCD Screen Replacement: 8 단계, 이미지 2/3 Craig CMP801 LCD Screen Replacement: 8 단계, 이미지 3/3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
  9. Craig CMP801 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 1/3 Craig CMP801 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 2/3 Craig CMP801 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3/3
    • Open the three black flaps located on each side of the motherboard.
  10. Craig CMP801 LCD Screen Replacement: 10 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 10 단계, 이미지 2/2
    • Then detach each of the three tabs from the LCD screen.
  11. Craig CMP801 LCD Screen Replacement: 11 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 11 단계, 이미지 2/2
    • Using a Philips 0 Screwdriver, remove the screws connecting the speaker to the motherboard.
    • Remove black plastic speaker holder.
  12. Craig CMP801 LCD Screen Replacement: 12 단계, 이미지 1/1
    • Remove the gray tape connecting the motherboard to the metal slate.
    • Use a spudger to separate the metal slate from the front touch screen.
  13. Craig CMP801 LCD Screen Replacement: 13 단계, 이미지 1/2 Craig CMP801 LCD Screen Replacement: 13 단계, 이미지 2/2
    • Carefully slide out the metal slate and LCD screen from underneath the motherboard.
  14. Craig CMP801 LCD Screen Replacement: 14 단계, 이미지 1/1
    • Flip over the metal slate and separate the LCD screen from it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anh
회원 가입일: 09/25/17
304 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 1,094
