주요 콘텐츠로 건너뛰기
Craig CMP801 Volume Controls Replacement
필요한 것
  1. Craig CMP801 Volume Controls Replacement, Back Cover: 1 단계, 이미지 1/2 Craig CMP801 Volume Controls Replacement, Back Cover: 1 단계, 이미지 2/2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Volume Controls Replacement: 2 단계, 이미지 1/2 Craig CMP801 Volume Controls Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Volume Controls Replacement: 3 단계, 이미지 1/2 Craig CMP801 Volume Controls Replacement: 3 단계, 이미지 2/2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Volume Controls Replacement, Volume Controls: 4 단계, 이미지 1/2 Craig CMP801 Volume Controls Replacement, Volume Controls: 4 단계, 이미지 2/2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 Volume Controls Replacement: 5 단계, 이미지 1/2 Craig CMP801 Volume Controls Replacement: 5 단계, 이미지 2/2
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 Volume Controls Replacement: 6 단계, 이미지 1/2 Craig CMP801 Volume Controls Replacement: 6 단계, 이미지 2/2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
결론
Mohammed
회원 가입일: 09/25/17
150 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 266
