주요 콘텐츠로 건너뛰기
Craig Electronics CMP773 Volume/Power Control Button Replacement
필요한 것
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: 1 단계, 이미지 1개 중 1개
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: 2 단계, 이미지 1개 중 1개
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: 3 단계, 이미지 1개 중 1개
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: 4 단계, 이미지 1개 중 1개
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: 5 단계, 이미지 2개 중 1개 Craig Electronics CMP773 Volume/Power Control Button Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the old button and replace it with the new one.
결론
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
작성자
3다른 기여자 명과 함께
Jessie L Morris
회원 가입일: 03/26/18
171 평판
안내서 1개를 작성함
IUPUI, Team S1-G5, Harley Spring 2018 IUPUI, Team S1-G5, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G5
6 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 8
전체 시간: 255
