주요 콘텐츠로 건너뛰기
Crayola Crayon Maker Light Bulb Removal and Replacement
필요한 것
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 1/3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 2/3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 3/3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: 2 단계, 이미지 1/3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: 2 단계, 이미지 2/3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: 2 단계, 이미지 3/3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: 3 단계, 이미지 1/3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: 3 단계, 이미지 2/3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: 3 단계, 이미지 3/3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Heidi Clarke
회원 가입일: 09/21/14
222 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 33
전체 시간: 6,543
