주요 콘텐츠로 건너뛰기
Crayola Crayon Maker Sliding Lock Mechanism Replacement
필요한 것
  1. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 1/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 2/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 3/3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 2 단계, 이미지 1/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 2 단계, 이미지 2/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 2 단계, 이미지 3/3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 3 단계, 이미지 1/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 3 단계, 이미지 2/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 3 단계, 이미지 3/3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 4 단계, 이미지 1/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 4 단계, 이미지 2/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 4 단계, 이미지 3/3
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 5 단계, 이미지 1/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 5 단계, 이미지 2/3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 5 단계, 이미지 3/3
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: 6 단계, 이미지 1/2 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: 6 단계, 이미지 2/2
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
결론
Heidi Clarke
회원 가입일: 09/21/14
222 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 23
전체 시간: 724
