주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Crayola Crayon Maker Sliding Lock Mechanism Replacement
필요한 것
  1. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 3개 중 1개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 3개 중 2개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 1 단계, 이미지 3개 중 3개
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
    댓글 쓰기
  2. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 2 단계, 이미지 3개 중 1개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 2 단계, 이미지 3개 중 2개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 2 단계, 이미지 3개 중 3개
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
    댓글 쓰기
  3. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 3 단계, 이미지 3개 중 1개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 3 단계, 이미지 3개 중 2개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 3 단계, 이미지 3개 중 3개
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
    댓글 쓰기
  4. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 4 단계, 이미지 3개 중 1개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 4 단계, 이미지 3개 중 2개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 4 단계, 이미지 3개 중 3개
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
    댓글 쓰기
  5. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 5 단계, 이미지 3개 중 1개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 5 단계, 이미지 3개 중 2개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 5 단계, 이미지 3개 중 3개
    • Locate the clear plastic arm inside the control box.
    댓글 쓰기
  6. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: 6 단계, 이미지 2개 중 1개 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: 6 단계, 이미지 2개 중 2개
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
10다른 기여자 명과 함께
Heidi Clarke
회원 가입일: 09/21/14
222 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 28
전체 시간: 1,165
