주요 콘텐츠로 건너뛰기
Creality Ender 3 V2 Extruder Nozzle Replacement
필요한 것
  1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: 1 단계, 이미지 1/1
    • Move the extruder carriage to the center of the machine.
  2. Creality Ender 3 V2 Extruder Nozzle Replacement: 2 단계, 이미지 1/1
    • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
  3. Creality Ender 3 V2 Extruder Nozzle Replacement: 3 단계, 이미지 1/1
    • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
  4. Creality Ender 3 V2 Extruder Nozzle Replacement: 4 단계, 이미지 1/3 Creality Ender 3 V2 Extruder Nozzle Replacement: 4 단계, 이미지 2/3 Creality Ender 3 V2 Extruder Nozzle Replacement: 4 단계, 이미지 3/3
    • Remove the silicon sleeve around the heat block.
    • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
  5. Creality Ender 3 V2 Extruder Nozzle Replacement: 5 단계, 이미지 1/2 Creality Ender 3 V2 Extruder Nozzle Replacement: 5 단계, 이미지 2/2
    • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
    • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
  6. Creality Ender 3 V2 Extruder Nozzle Replacement: 6 단계, 이미지 1/3 Creality Ender 3 V2 Extruder Nozzle Replacement: 6 단계, 이미지 2/3 Creality Ender 3 V2 Extruder Nozzle Replacement: 6 단계, 이미지 3/3
    • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
    • If the nozzle is fully cooled, remove the nozzle.
  7. Creality Ender 3 V2 Extruder Nozzle Replacement: 7 단계, 이미지 1/2 Creality Ender 3 V2 Extruder Nozzle Replacement: 7 단계, 이미지 2/2
    • Screw on the new nozzle into the heat block with your wrench.
    • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
    • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
결론
Print away!
다른 6명이 해당 안내서를 완성하였습니다.
Marc-Anthony Cardoso
회원 가입일: 03/24/21
223 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G3, Riel Spring 2021 UMass Dartmouth, Team S2-G3, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G3
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 100
30일 전: 591
전체 시간: 16,937
