주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creality Ender 3 V2 Extruder Nozzle Replacement
필요한 것
    1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: 1 단계, 이미지 1개 중 1개
      • Move the extruder carriage to the center of the machine.
      댓글 쓰기
    2. Creality Ender 3 V2 Extruder Nozzle Replacement: 2 단계, 이미지 1개 중 1개
      • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
      댓글 쓰기
    3. Creality Ender 3 V2 Extruder Nozzle Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
      댓글 쓰기
    4. Creality Ender 3 V2 Extruder Nozzle Replacement: 4 단계, 이미지 3개 중 1개 Creality Ender 3 V2 Extruder Nozzle Replacement: 4 단계, 이미지 3개 중 2개 Creality Ender 3 V2 Extruder Nozzle Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the silicon sleeve around the heat block.
      • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
      댓글 쓰기
    5. Creality Ender 3 V2 Extruder Nozzle Replacement: 5 단계, 이미지 2개 중 1개 Creality Ender 3 V2 Extruder Nozzle Replacement: 5 단계, 이미지 2개 중 2개
      • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
      • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
      댓글 쓰기
    6. Creality Ender 3 V2 Extruder Nozzle Replacement: 6 단계, 이미지 3개 중 1개 Creality Ender 3 V2 Extruder Nozzle Replacement: 6 단계, 이미지 3개 중 2개 Creality Ender 3 V2 Extruder Nozzle Replacement: 6 단계, 이미지 3개 중 3개
      • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
      • If the nozzle is fully cooled, remove the nozzle.
      댓글 쓰기
    7. Creality Ender 3 V2 Extruder Nozzle Replacement: 7 단계, 이미지 2개 중 1개 Creality Ender 3 V2 Extruder Nozzle Replacement: 7 단계, 이미지 2개 중 2개
      • Screw on the new nozzle into the heat block with your wrench.
      • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
      • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
      댓글 쓰기
결론
Print away!
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Marc-Anthony Cardoso
회원 가입일: 03/24/21
247 평판
안내서 1개를 작성함
UMass Dartmouth, Team S2-G3, Riel Spring 2021 UMass Dartmouth, Team S2-G3, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G3
1 회원
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 39
지난 30일: 209
전체 시간: 27,418
