주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creating a Bootable SD Card
필요한 것
  1. Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 1 단계, 이미지 3개 중 1개 Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 1 단계, 이미지 3개 중 2개 Creating a Bootable SD Card, Downloading Raspberry Pi Imager: 1 단계, 이미지 3개 중 3개
    • To create our Bootable SD Card we will need the Official Raspberry Pi Imager software. This software is completely free, and can be downloaded here.
    댓글 쓰기
  2. Creating a Bootable SD Card, Configuring your SD Card: 2 단계, 이미지 1개 중 1개
    • Once your download has been completed, open the Pi Imager program, and insert your SD Card into your computer. The Imager software should automatically detect your SD Card, and will begin to format the card.
    • Formatting your SD Card will erase any content that has been saved onto the card. Be sure to backup any photos or files to your machine before formatting.
    댓글 쓰기
  3. Creating a Bootable SD Card, Select your Operating System: 3 단계, 이미지 2개 중 1개 Creating a Bootable SD Card, Select your Operating System: 3 단계, 이미지 2개 중 2개
    • Once your SD Card has been targeted, you'll need to select the Operating System that you would like loaded onto your SD Card.
    • Imager comes pre-loaded with several operating systems, however you can select a custom OS by scrolling to the bottom of the list of OS'.
    댓글 쓰기
  4. Creating a Bootable SD Card, Choosing your SD Card: 4 단계, 이미지 2개 중 1개 Creating a Bootable SD Card, Choosing your SD Card: 4 단계, 이미지 2개 중 2개
    • Once your OS has been selected, select your inserted SD card.
    댓글 쓰기
  5. Creating a Bootable SD Card, Writing the OS to your SD Card: 5 단계, 이미지 2개 중 1개 Creating a Bootable SD Card, Writing the OS to your SD Card: 5 단계, 이미지 2개 중 2개
    • Once you have your SD Card selected, click on the Write button. If prompted enter the password to your computer.
    • This step will erase any data that is on the SD Card. Be sure to back up any files or photos you wish to save to your computer
    댓글 쓰기
    • When the installation is complete, Imager will prompt you to remove your SD Card.
    • Imager will automatically eject your SD Card, so it should be safe for you to remove it once the installation is complete.
    • To begin using your Bootable SD Card, simply insert the card into your Raspberry Pi, and power on your device.
    댓글 쓰기
    • It is possible that at the moment you begin to WRITE the OS to your SD Card an alert may appear warning that the card is write protected. This happens when the switch on the left side of the SD is in protection mode.
    • You can solve this by ejecting the SD Card and move the lever to the side opposite, then repeat the OS selection operation. and of the SD Card.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Ema.exe
회원 가입일: 06/19/22
538 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 92
전체 시간: 1,852
