소개
Use this guide to create a buttonhole with your sewing machine. We’re using a Bernina 830, but the process should be similar for all sewing machines with a mechanical buttonhole dial. Since every sewing machine is different, refer to your sewing machine’s owner’s manual for specific information. In this guide we’re using contrasting thread for visibility. When it comes time for your actual project, you’ll want to use thread that matches the color of your fabric.
필요한 것
Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
Set your buttonhole dial to five.
This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
