메인 콘텐츠로 스킵하기
소개
Use this guide to create a buttonhole with your sewing machine. We’re using a Bernina 830, but the process should be similar for all sewing machines with a mechanical buttonhole dial. Since every sewing machine is different, refer to your sewing machine’s owner’s manual for specific information. In this guide we’re using contrasting thread for visibility. When it comes time for your actual project, you’ll want to use thread that matches the color of your fabric.
  1. Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual. Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
    • Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
    • Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
  2. Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk. You can measure your button if you aren't sure.
    • Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk.
    • You can measure your button if you aren't sure.
    • Align the sewing machine at the upper left corner of the buttonhole.
  3. Lower the presser foot. Lower the presser foot.
  4. Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5. Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
    • Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
  5. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  6. Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual. Every time you adjust this dial, your needle will move. That's okay; it's supposed to do that. Start sewing. Sew to your second line.
    • Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual.
    • Every time you adjust this dial, your needle will move. That's okay; it's supposed to do that.
    • Start sewing. Sew to your second line.
  7. Set your button hole dial to two. Sew the bar tack at the bottom of the buttonhole.
    • Set your button hole dial to two.
    • Sew the bar tack at the bottom of the buttonhole.
    • Setting the button hole dial to two tells your sewing machine what to do, all you need to do is sew a few stitches to create the bar tack.
  8. Set your buttonhole dial to three. Sew up the second side of your buttonhole, stopping at your top mark.
    • Set your buttonhole dial to three.
    • Sew up the second side of your buttonhole, stopping at your top mark.
  9. Set your buttonhole dial to four. Sew the top bar tack at the top of the buttonhole.
    • Set your buttonhole dial to four.
    • Sew the top bar tack at the top of the buttonhole.
  10. Set your buttonhole dial to five. This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
    • Set your buttonhole dial to five.
    • This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
  11. Clip the threads, freeing the fabric from the machine. Clip any extra loose threads.
    • Clip the threads, freeing the fabric from the machine.
    • Clip any extra loose threads.
  12. Use a hobby knife to cut open the buttonhole. Be careful not to cut through the stitching, you only want to cut the fabric between the rows of stitching.
    • Use a hobby knife to cut open the buttonhole.
    • Be careful not to cut through the stitching, you only want to cut the fabric between the rows of stitching.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 2012년 03월 05일
81,672 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
101 회원들
안내서 8,735개 작성하였습니다
I got up to position (!) 2 ok, then when I tried to go back up on position 3 it didn't work and just chewed up my fabric. Is it supposed to go backwards, or are you supposed to turn the fabric around? Did I do something wrong?
Holly - 답글
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
Roszarie - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 116
전체 시간: 21,637
