주요 콘텐츠로 건너뛰기
Creative Nomad II Lock/Unlock Switch Replacement
필요한 것
  1. Creative Nomad II Lock/Unlock Switch Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using your thumb, slide down and remove the battery cover.
  2. Creative Nomad II Lock/Unlock Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Creative Nomad II Lock/Unlock Switch Replacement, Smart Media Card: 3 단계, 이미지 1개 중 1개
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Creative Nomad II Lock/Unlock Switch Replacement, Back Cover: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
  5. Creative Nomad II Lock/Unlock Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the back cover off of the NOMAD II.
    • Remove the rubber USB port cover, the connected buttons along the left edge, and the plastic lock/unlock button on the upper right edge of the device.
  6. Creative Nomad II Lock/Unlock Switch Replacement, Battery Compartment: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
  7. Creative Nomad II Lock/Unlock Switch Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the battery compartment.
  8. Creative Nomad II Lock/Unlock Switch Replacement, Circuit Boards: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
  9. Creative Nomad II Lock/Unlock Switch Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
  10. Creative Nomad II Lock/Unlock Switch Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the circuit boards out of the back cover.
    • During reinstallation, firmly press the top of the circuit boards into the cover until you hear a click.
  11. Creative Nomad II Lock/Unlock Switch Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pry the circuit boards apart.
    • This must be done with the USB port facing up, as shown.
  12. Creative Nomad II Lock/Unlock Switch Replacement, Lock/Unlock Switch: 12 단계, 이미지 1개 중 1개
    • Desolder the seven solder joints which hold the lock switch in place.
    • Install the new lock/unlock switch.
결론
작성자
8다른 기여자 명과 함께
Craig Fischer
회원 가입일: 01/24/12
21 평판
안내서 2개를 작성함
Cal Poly, Team 9-2, Regan Winter 2012 Cal Poly, Team 9-2, Regan Winter 2012 회원
CPSU-REGAN-W12S9G2
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 1,913
