주요 콘텐츠로 건너뛰기
Creative Nomad Jukebox Zen Display Screen Replacement
필요한 것
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 1 단계, 이미지 1/3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 1 단계, 이미지 2/3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 1 단계, 이미지 3/3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: 2 단계, 이미지 1/3 Creative Nomad Jukebox Zen Display Screen Replacement: 2 단계, 이미지 2/3 Creative Nomad Jukebox Zen Display Screen Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: 3 단계, 이미지 1/1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: 4 단계, 이미지 1/1
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: 5 단계, 이미지 1/2 Creative Nomad Jukebox Zen Display Screen Replacement: 5 단계, 이미지 2/2
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: 6 단계, 이미지 1/2 Creative Nomad Jukebox Zen Display Screen Replacement: 6 단계, 이미지 2/2
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: 7 단계, 이미지 1/1
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
결론
Austin Shaw
회원 가입일: 03/08/17
101 평판
안내서 1개 작성함
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 525
