주요 콘텐츠로 건너뛰기
Creative Nomad Jukebox Zen Display Screen Replacement
필요한 것
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 1 단계, 이미지 3개 중 1개 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 1 단계, 이미지 3개 중 2개 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: 1 단계, 이미지 3개 중 3개
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: 2 단계, 이미지 3개 중 1개 Creative Nomad Jukebox Zen Display Screen Replacement: 2 단계, 이미지 3개 중 2개 Creative Nomad Jukebox Zen Display Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: 3 단계, 이미지 1개 중 1개
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: 5 단계, 이미지 2개 중 1개 Creative Nomad Jukebox Zen Display Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: 6 단계, 이미지 2개 중 1개 Creative Nomad Jukebox Zen Display Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
결론
작성자
4다른 기여자 명과 함께
Austin Shaw
회원 가입일: 03/08/17
101 평판
안내서 1개를 작성함
IUPUI, Team S4-G5, Baechle Spring 2017 IUPUI, Team S4-G5, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 697
