주요 콘텐츠로 건너뛰기
Creative Zen V Plus Logic Board Replacement
필요한 것
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: 1 단계, 이미지 1/1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: 3 단계, 이미지 1/1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: 4 단계, 이미지 1/2 Creative Zen V Plus Logic Board Replacement: 4 단계, 이미지 2/2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: 5 단계, 이미지 1/1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: 6 단계, 이미지 1/3 Creative Zen V Plus Logic Board Replacement: 6 단계, 이미지 2/3 Creative Zen V Plus Logic Board Replacement: 6 단계, 이미지 3/3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: 7 단계, 이미지 1/1
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
결론
Joel Ng
회원 가입일: 10/19/16
239 평판
안내서 1개 작성함
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 458
