주요 콘텐츠로 건너뛰기
Creative Zen Vision W Battery Replacement
필요한 것
  1. Creative Zen Vision W Battery Replacement, Battery Removal: 1 단계, 이미지 3개 중 1개 Creative Zen Vision W Battery Replacement, Battery Removal: 1 단계, 이미지 3개 중 2개 Creative Zen Vision W Battery Replacement, Battery Removal: 1 단계, 이미지 3개 중 3개
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Creative Zen Vision W Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
    • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
  3. Creative Zen Vision W Battery Replacement: 3 단계, 이미지 3개 중 1개 Creative Zen Vision W Battery Replacement: 3 단계, 이미지 3개 중 2개 Creative Zen Vision W Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
결론
Follow these instructions in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Tim Wilson
회원 가입일: 04/11/13
143 평판
안내서 6개를 작성함
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 회원
CPSU-REGAN-S13S17G2
4 회원들
안내서 8개를 작성함
3가이드 댓글
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - 답글
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - 답글
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 77
전체 시간: 6,588
