주요 콘텐츠로 건너뛰기
소개
Use this guide to replace a dead battery.
부품
지정된 부품이 없습니다.
  1. Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device. Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device. Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Remove the three exposed screws (4 mm) using a #0 Phillips. Peel off the the sticker that says "Creative Warranty Void if broken" and remove the screw (4 mm) beneath with a #0 Phillips.
    • Remove the three exposed screws (4 mm) using a #0 Phillips.
    • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the screw (4 mm) beneath with a #0 Phillips.
  3. Remove the battery from the casing by bending the sides. The battery should pop out.  Be careful not to snap the case. Remove the battery from the casing by bending the sides. The battery should pop out.  Be careful not to snap the case. Remove the battery from the casing by bending the sides. The battery should pop out.  Be careful not to snap the case.
    • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tim Wilson
회원 가입일: 2013년 04월 11일
128 평판
안내서 6개 작성하였습니다
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 회원
CPSU-REGAN-S13S17G2
4 회원들
안내서 8개 작성하였습니다
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - 답글
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - 답글
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 37
전체 시간: 3,451
