이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
