주요 콘텐츠로 건너뛰기
Creative Zen Vision W Front Cover Replacement
필요한 것
  1. Creative Zen Vision W Front Cover Replacement, Front Cover: 1 단계, 이미지 1/2 Creative Zen Vision W Front Cover Replacement, Front Cover: 1 단계, 이미지 2/2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W Front Cover Replacement: 2 단계, 이미지 1/3 Creative Zen Vision W Front Cover Replacement: 2 단계, 이미지 2/3 Creative Zen Vision W Front Cover Replacement: 2 단계, 이미지 3/3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
결론
Gabriele Pregadio
회원 가입일: 04/17/13
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 회원
CPSU-REGAN-S13S17G2
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Fantastic but does anyone know where I can get this part?
VegetaFlex4Fitness - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 424
