주요 콘텐츠로 건너뛰기
Creative Zen Vision W Hard Drive Replacement
필요한 것
  1. Creative Zen Vision W Hard Drive Replacement, Battery Removal: 1 단계, 이미지 1/3 Creative Zen Vision W Hard Drive Replacement, Battery Removal: 1 단계, 이미지 2/3 Creative Zen Vision W Hard Drive Replacement, Battery Removal: 1 단계, 이미지 3/3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Hard Drive Replacement, Back Cover: 2 단계, 이미지 1/1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Creative Zen Vision W Hard Drive Replacement: 3 단계, 이미지 1/2 Creative Zen Vision W Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Creative Zen Vision W Hard Drive Replacement: 4 단계, 이미지 1/3 Creative Zen Vision W Hard Drive Replacement: 4 단계, 이미지 2/3 Creative Zen Vision W Hard Drive Replacement: 4 단계, 이미지 3/3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
  5. Creative Zen Vision W Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/2 Creative Zen Vision W Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
    • Lift the metal cover off.
  6. Creative Zen Vision W Hard Drive Replacement: 6 단계, 이미지 1/3 Creative Zen Vision W Hard Drive Replacement: 6 단계, 이미지 2/3 Creative Zen Vision W Hard Drive Replacement: 6 단계, 이미지 3/3
    • Lift the white and black ribbon connection off of the motherboard.
    • The hard drive can now be removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tim Wilson
회원 가입일: 04/11/13
143 평판
안내서 6개 작성하였습니다
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 회원
CPSU-REGAN-S13S17G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 23
전체 시간: 3,715
