소개
This guide will show you how to replace the hard drive in your device. Use this guide if your hard drive is broken and in need of replacement.
부품
지정된 부품이 없습니다.
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
Lift the metal cover off.
다른 2명이 해당 안내서를 완성하였습니다.
