이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
Carefully pull the back cover off of the rest of the device.
The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
The USB input cover on the bottom of the device may also fall off.
Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
Lift the metal cover off.
Lift the white and black ribbon connection off of the motherboard.
The hard drive can now be removed.
다른 2명이 해당 안내서를 완성하였습니다.
