주요 콘텐츠로 건너뛰기
Creative Zen Vision W Keypad Replacement
필요한 것
  1. Creative Zen Vision W Keypad Replacement, Front Cover: 1 단계, 이미지 1/2 Creative Zen Vision W Keypad Replacement, Front Cover: 1 단계, 이미지 2/2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W Keypad Replacement: 2 단계, 이미지 1/3 Creative Zen Vision W Keypad Replacement: 2 단계, 이미지 2/3 Creative Zen Vision W Keypad Replacement: 2 단계, 이미지 3/3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W Keypad Replacement, LCD Screen: 3 단계, 이미지 1/3 Creative Zen Vision W Keypad Replacement, LCD Screen: 3 단계, 이미지 2/3 Creative Zen Vision W Keypad Replacement, LCD Screen: 3 단계, 이미지 3/3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W Keypad Replacement: 4 단계, 이미지 1/1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W Keypad Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W Keypad Replacement: 6 단계, 이미지 1/3 Creative Zen Vision W Keypad Replacement: 6 단계, 이미지 2/3 Creative Zen Vision W Keypad Replacement: 6 단계, 이미지 3/3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
  7. Creative Zen Vision W Keypad Replacement, Keypad: 7 단계, 이미지 1/1
    • Peel the orange sticker off of the motherboard.
  8. Creative Zen Vision W Keypad Replacement: 8 단계, 이미지 1/2 Creative Zen Vision W Keypad Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
  9. Creative Zen Vision W Keypad Replacement: 9 단계, 이미지 1/2 Creative Zen Vision W Keypad Replacement: 9 단계, 이미지 2/2
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
결론
Tim Wilson
회원 가입일: 04/11/13
143 평판
안내서 6개 작성하였습니다
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 회원
CPSU-REGAN-S13S17G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 413
