주요 콘텐츠로 건너뛰기
Creative Zen Vision W LCD Screen Replacement
필요한 것
  1. Creative Zen Vision W LCD Screen Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Creative Zen Vision W LCD Screen Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Creative Zen Vision W LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Creative Zen Vision W LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 1개 Creative Zen Vision W LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 2개 Creative Zen Vision W LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 3개
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Creative Zen Vision W LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Creative Zen Vision W LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Tim Wilson
회원 가입일: 04/11/13
143 평판
안내서 6개를 작성함
Cal Poly, Team 17-2, Regan Spring 2013 Cal Poly, Team 17-2, Regan Spring 2013 회원
CPSU-REGAN-S13S17G2
4 회원들
안내서 8개를 작성함
1가이드 댓글
Where can I get the screen
Home Watch - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 1,554
