소개
This guide will show you how to remove and install a new LCD screen in your device. Use this guide if your screen is broken or damaged and needs to be replaced.
필요한 것
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
