소개
This guide will show you how to access the motherboard and speaker on your device.
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
When the cover has been lifted off the screen, use your hands to remove it from the device.
The button pad may fall off when the cover is removed.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
Lift the metal cover off.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
If the main board on vision w hard disk connector has 44 pins as vision m has but the vision w has a zif 40 pin ribbon in to the hard disk.it make me belive that it is possible to use a zif connector style hard disk on vision M to with the hard disk cable from vision w?Or does i miss something?i want to try to use a 1.8 hard disk with around 100 GB capacity on vision M if possible
