주요 콘텐츠로 건너뛰기
Creative Zen X-Fi LCD Screen Replacement
필요한 것
  1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: 1 단계, 이미지 3개 중 1개 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: 1 단계, 이미지 3개 중 2개 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: 1 단계, 이미지 3개 중 3개
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: 2 단계, 이미지 1개 중 1개
    • The black rubber button pad can be removed by simply picking it up.
  3. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: 3 단계, 이미지 1개 중 1개
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: 4 단계, 이미지 1개 중 1개
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: 5 단계, 이미지 1개 중 1개
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: 6 단계, 이미지 1개 중 1개
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: 7 단계, 이미지 1개 중 1개
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: 8 단계, 이미지 2개 중 1개 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: 8 단계, 이미지 2개 중 2개
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
  9. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: 9 단계, 이미지 2개 중 1개 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: 9 단계, 이미지 2개 중 2개
    • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
  10. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: 10 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
    • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 22
전체 시간: 1,740
