주요 콘텐츠로 건너뛰기
Creative Ziio 7" Battery Replacement
필요한 것
  1. Creative Ziio 7" Battery Replacement, Back Panel: 1 단계, 이미지 1/3 Creative Ziio 7" Battery Replacement, Back Panel: 1 단계, 이미지 2/3 Creative Ziio 7" Battery Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Battery Replacement, Battery: 2 단계, 이미지 1/3 Creative Ziio 7" Battery Replacement, Battery: 2 단계, 이미지 2/3 Creative Ziio 7" Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
    • The last point is hidden by the soldering iron.
    • Remove the copper plate once all the solder points are undone.
  3. Creative Ziio 7" Battery Replacement: 3 단계, 이미지 1/2 Creative Ziio 7" Battery Replacement: 3 단계, 이미지 2/2
    • Remove adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the mother board.
  4. Creative Ziio 7" Battery Replacement: 4 단계, 이미지 1/2 Creative Ziio 7" Battery Replacement: 4 단계, 이미지 2/2
    • With a spudger, pry the battery from the back of the LCD screen.
    • The battery is attached with double sided foam tape. When prying, the tape will probably not come apart easy. This will result in the tape tearing and leaving residue.
  5. Creative Ziio 7" Battery Replacement: 5 단계, 이미지 1/1
    • Remove old battery and dispose of it responsibly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryce Simmons
회원 가입일: 04/16/13
147 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 회원
CPSU-MANESS-S13S14G10
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 955
