주요 콘텐츠로 건너뛰기
Creative Ziio 7" Camera Replacement
필요한 것
  1. Creative Ziio 7" Camera Replacement, Back Panel: 1 단계, 이미지 1/3 Creative Ziio 7" Camera Replacement, Back Panel: 1 단계, 이미지 2/3 Creative Ziio 7" Camera Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Camera Replacement, Camera: 2 단계, 이미지 1/3 Creative Ziio 7" Camera Replacement, Camera: 2 단계, 이미지 2/3 Creative Ziio 7" Camera Replacement, Camera: 2 단계, 이미지 3/3
    • Unscrew the four Phillips #00 screws, each measuring 3mm, located at the corners of the motherboard.
  3. Creative Ziio 7" Camera Replacement: 3 단계, 이미지 1/3 Creative Ziio 7" Camera Replacement: 3 단계, 이미지 2/3 Creative Ziio 7" Camera Replacement: 3 단계, 이미지 3/3
    • Disconnect the ribbon cable located near the edge of the motherboard in the bottom right corner of the device.
  4. Creative Ziio 7" Camera Replacement: 4 단계, 이미지 1/2 Creative Ziio 7" Camera Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift up the motherboard carefully.
    • A mesh-like strip on the right side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip. Use tweezers or pliers to pull on the strip and unplug it.
  5. Creative Ziio 7" Camera Replacement: 5 단계, 이미지 1/2 Creative Ziio 7" Camera Replacement: 5 단계, 이미지 2/2
    • Lift up the motherboard and locate the ribbon cable (burnt orange-colored strip) centered on top of the motherboard.
    • The ribbon cable with the attached camera is plugged into the motherboard.
    • Unplug the ribbon cable using your fingers to pull up on the flap.
  6. Creative Ziio 7" Camera Replacement: 6 단계, 이미지 1/2 Creative Ziio 7" Camera Replacement: 6 단계, 이미지 2/2
    • Use a spudger to pry the camera away from the rubber camera mount.
    • Do not remove the entire rubber camera mount. Only remove the camera attached with adhesive.
    • Remove the broken camera and use electronic-friendly adhesive to attach a new camera.
결론
In summary, following these steps should allow you to replace the camera on your Creative Ziio 7" tablet effectively. Just make sure to power off the device, handle components carefully, and test the new camera thoroughly post-installation. If you run into any issues, refer to the manufacturer's instructions or seek professional assistance for a smooth repair process.
다른 2명이 해당 안내서를 완성하였습니다.
Kendall Ruggles
회원 가입일: 04/16/13
35 평판
안내서 1개 작성함
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 회원
CPSU-MANESS-S13S14G10
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 35
전체 시간: 367
