이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the four 3mm Philips #00 screws around the large silver battery.
Remove the four 4mm Philips #00 screws on the edges of the circuit board.
Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
Carefully lift up the circuit board on the detached side.
Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - 답글
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
