소개
In this guide, you will be able to remove the motherboard from a creative ZiiO and use a soldering iron while doing so.
필요한 것
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the copper plate covering the motherboard by desoldering the ten solder points.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
