주요 콘텐츠로 건너뛰기
Cricut Maker Top Door/ Lid Replacement
필요한 것
  1. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 1개 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 2개 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 3개
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
    The outer two attachment points of my Cricut were actually glued on, and I had to reach in with the torx driver and remove them while the strip was still on, to be able to get the lid off. On inspection, there would have been no way to lift the strip off in the way described here.
    cjberry - 답글
  2. Cricut Maker Top Door/ Lid Replacement: 2 단계, 이미지 2개 중 1개 Cricut Maker Top Door/ Lid Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Top Door/ Lid Replacement: 3 단계, 이미지 3개 중 1개 Cricut Maker Top Door/ Lid Replacement: 3 단계, 이미지 3개 중 2개 Cricut Maker Top Door/ Lid Replacement: 3 단계, 이미지 3개 중 3개
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
    The lid of my Cricut maker 3 was removable by pulling upwards, while the lid was still open. It slides right off. The prying approach as described in this step is unnecessary, and could break the attachment points if forced.
    Chris Schnabel - 답글
  4. Cricut Maker Top Door/ Lid Replacement: 4 단계, 이미지 1개 중 1개
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
    Where is/are the steps to get to the point of seeing the motor? I've got the top cover off, but that doesn't reveal the motor. There are steps missing between 4 and 5.
    Patty Ellis - 답글
    There are x7 small screws on the inside upper panel that have to be removed as well as x4 long screws under the feet of the machine.
    I had to turn on my machine and send a project to it to have the cutter mechanism move out of the way to remove some of the screws. Once all the screws have been removed the case can be pulled away, but you have to be careful when removing because there are some wires connecting the buttons on the case to the harddrive.
    Margarita Armendariz -
    Where can I get the replacement part(s) to make the door stay up and open?
    David L Dabbs - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Devyn White
회원 가입일: 09/20/22
1,113 평판
안내서 5개를 작성함
Austin Community College, Team 9-1, Watkins Fall 2022 Austin Community College, Team 9-1, Watkins Fall 2022 회원
AUSTINCC-WATKINS-F22S9G1
3 회원들
안내서 23개를 작성함
댓글 2개
Where i can buy Cricut Maker Top Door/ Lid Replacement?
Maria Ventura - 답글
Our Circut Maker lid will not stay open. It closes on its own within a few seconds. I was wondering if there was a fix or a repair I could do. It is 10 months old and Circut told us it wasn’t covered under the two year warranty.
K. Moore
Keith Moore - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 44
지난 30일: 141
전체 시간: 3,569
