주요 콘텐츠로 건너뛰기
Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement
필요한 것
  1. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: 1 단계, 이미지 1/3 Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: 1 단계, 이미지 2/3 Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: 1 단계, 이미지 3/3
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  2. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Bobber Valve: 2 단계, 이미지 1/1
    • Flip the lid over and expose plastic washer.
  3. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement: 3 단계, 이미지 1/1
    • Pull the plastic washer off the bobber valve and allow the bobber valve to fall out
결론
다른 6명이 해당 안내서를 완성하였습니다.
William Kelly
회원 가입일: 09/24/18
745 평판
안내서 7개 작성하였습니다
댓글 7개
Ok I followed your directions but the new valve just keeps calling out?
dpataky1952 - 답글
First time I used this but the bobber valve ports steam and does not stop ( unit is brand new )
Archerkc - 답글
would be nice to see the other side of this. is it just supposed to be a hole on the outside up top? it is letting out air…when im trying to pressure cook.
shaycooks2 - 답글
Ditto I was wanting to know the same thing!
kate2272 -
Ditto. Mine does the same thing.. suggestions?
Tina Royce - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 99
전체 시간: 26,639
