주요 콘텐츠로 건너뛰기
Crock-Pot Express Crock Multi-Cooker Power Cord Replacement
  1. Crock-Pot Express Crock Multi-Cooker Power Cord Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Power Cord Replacement: 2 단계, 이미지 1개 중 1개
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Power Cord Replacement: 3 단계, 이미지 2개 중 1개 Crock-Pot Express Crock Multi-Cooker Power Cord Replacement: 3 단계, 이미지 2개 중 2개
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
결론
다른 2명이 해당 안내서를 완성하였습니다.
7가이드 댓글
Still does not work.
Darlene Reynolds - 답글
My Slow cooker will not reset its self So I can brown sorta . It still says put on the lid
Ronnie Sherrington - 답글
Crook pot lid won't unlock after unit is cool
Maureen Smilkstein - 답글
Lid won't unlock after pot has cooled down. Suggestions please
You can unlock it by pushing down on the home next to the streaming element
Amor Pad -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 38
전체 시간: 6,422
