주요 콘텐츠로 건너뛰기
Crosley 33301 Front Glass Replacement
필요한 것
  1. Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 1 단계, 이미지 3개 중 1개 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 1 단계, 이미지 3개 중 2개 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: 1 단계, 이미지 3개 중 3개
    • Rotate Clock till the face/or front is pointing away from you.
    • Continue on by unscrewing the 5.5 millimeter screws with your hands.
    • Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
  2. Crosley 33301 Front Glass Replacement: 2 단계, 이미지 2개 중 1개 Crosley 33301 Front Glass Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the two remaining screws with a PH2 bit.
    • Do not be afraid to use additional force to remove these screws. Just be careful not to break the clock!
  3. Crosley 33301 Front Glass Replacement: 3 단계, 이미지 2개 중 1개 Crosley 33301 Front Glass Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the front part of the clock from the back frame.
    • No major force is required. The back frame should slide right off.
  4. Crosley 33301 Front Glass Replacement: 4 단계, 이미지 2개 중 1개 Crosley 33301 Front Glass Replacement: 4 단계, 이미지 2개 중 2개
    • You will notice that there are three small indents on alternate sides.
    • You will see small slits where the indents can slide through.
    • Twist the center counter clockwise so that the face and the back are no longer connected.
  5. Crosley 33301 Front Glass Replacement: 5 단계, 이미지 2개 중 1개 Crosley 33301 Front Glass Replacement: 5 단계, 이미지 2개 중 2개
    • Replace the front of the clock with your new glass face protector and settle it on the frame.
    • The glass for this clock is 10cm in diameter. It would be best to use glass that fits this measurement!
  6. Crosley 33301 Front Glass Replacement: 6 단계, 이미지 3개 중 1개 Crosley 33301 Front Glass Replacement: 6 단계, 이미지 3개 중 2개 Crosley 33301 Front Glass Replacement: 6 단계, 이미지 3개 중 3개
    • Apply the clock face back on the frame, then reverse your steps. Take a step back and admire your handiwork!
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tenaya
회원 가입일: 05/31/16
125 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 70
전체 시간: 2,452
