주요 콘텐츠로 건너뛰기
Crosley CR42 Band Replacement
필요한 것
  1. Crosley CR42  Band Replacement, Band: 1 단계, 이미지 1/1
    • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • If you believe the band may be broken or out of place, start by unplugging the record player.
  2. Crosley CR42  Band Replacement: 2 단계, 이미지 1/2 Crosley CR42  Band Replacement: 2 단계, 이미지 2/2
    • Make sure the needle is in its resting position off to the side.
    • Gently remove the turntable from the device by lifting it directly upward.
  3. Crosley CR42  Band Replacement: 3 단계, 이미지 1/1
    • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Inspect your band for any tears, rips, or obvious signs of stretching.
  4. Crosley CR42  Band Replacement: 4 단계, 이미지 1/1
    • Flip the turntable over.
    • Locate the notch on the back side of the turntable.
    • The notch will be on the outside edge of the turntable.
  5. Crosley CR42  Band Replacement: 5 단계, 이미지 1/2 Crosley CR42  Band Replacement: 5 단계, 이미지 2/2
    • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
    • Loop the band around the notch, the band should be taut.
  6. Crosley CR42  Band Replacement: 6 단계, 이미지 1/2 Crosley CR42  Band Replacement: 6 단계, 이미지 2/2
    • Place the turntable back onto the device.
    • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
  7. Crosley CR42  Band Replacement: 7 단계, 이미지 1/1
    • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • Job well done!
결승점
Roberto Rosila
회원 가입일: 01/26/14
319 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 회원
CPSU-MANESS-W14S1G38
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 90
전체 시간: 4,830
