주요 콘텐츠로 건너뛰기
Crosley CR42 Bushings Replacement
필요한 것
  1. Crosley CR42 Bushings Replacement, Bushings: 1 단계, 이미지 1/2 Crosley CR42 Bushings Replacement, Bushings: 1 단계, 이미지 2/2
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: 2 단계, 이미지 1/3 Crosley CR42 Bushings Replacement: 2 단계, 이미지 2/3 Crosley CR42 Bushings Replacement: 2 단계, 이미지 3/3
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: 3 단계, 이미지 1/3 Crosley CR42 Bushings Replacement: 3 단계, 이미지 2/3 Crosley CR42 Bushings Replacement: 3 단계, 이미지 3/3
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: 4 단계, 이미지 1/2 Crosley CR42 Bushings Replacement: 4 단계, 이미지 2/2
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: 5 단계, 이미지 1/1
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: 6 단계, 이미지 1/3 Crosley CR42 Bushings Replacement: 6 단계, 이미지 2/3 Crosley CR42 Bushings Replacement: 6 단계, 이미지 3/3
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: 7 단계, 이미지 1/2 Crosley CR42 Bushings Replacement: 7 단계, 이미지 2/2
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: 8 단계, 이미지 1/3 Crosley CR42 Bushings Replacement: 8 단계, 이미지 2/3 Crosley CR42 Bushings Replacement: 8 단계, 이미지 3/3
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roberto Rosila
회원 가입일: 01/26/14
319 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 회원
CPSU-MANESS-W14S1G38
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 3,087
