이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the device around so the line out port faces you.
Remove the ten 12 mm screws with the Phillips screwdriver.
Pull the line out port toward you so you can view the inside of the Crosley.
Locate the wires that connect the line out port to the inside of the device.
Pull on the two connections to remove them from the back of the line out port.
Remove the antenna wire from the line out port, then remove the line out port and set it aside.
Position yourself in front of the turntable to unscrew the three bushing bolts.
Pull the turntable out from the casing.
Remove the three bushing bolts.
Pinch the rubber bushing at the bottom, then pull downwards to remove it.
Repeat the previous step for the other two bushings.
다른 한 분이 해당 안내서를 완성하였습니다.
