주요 콘텐츠로 건너뛰기
Crosley CR704 Control Knobs Replacement
필요한 것
  1. Crosley CR704 Control Knobs Replacement, Safety: 1 단계, 이미지 1개 중 1개
    • Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
    • Make sure the turntable cover is closed so that nothing jostles out of place.
  2. Crosley CR704 Control Knobs Replacement: 2 단계, 이미지 1개 중 1개
    • Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
    • With some force, pry the knob off of its peg.
    • The knob should slide off smoothly, but beware of flying knobs!
  3. Crosley CR704 Control Knobs Replacement: 3 단계, 이미지 1개 중 1개
    • Applying some force, insert the replacement knob onto the peg.
결론
Test by turning on your radio and playing a tune. We suggest "Last Dance" by Dona Summer.
작성자
3다른 기여자 명과 함께
MarkAnthony
회원 가입일: 09/22/13
826 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 2,038
