주요 콘텐츠로 건너뛰기
Crosley CR704 Speaker Replacement
필요한 것
  1. Crosley CR704 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: 2 단계, 이미지 1/1
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: 3 단계, 이미지 1/1
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: 4 단계, 이미지 1/1
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
결론
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
다른 한 분이 해당 안내서를 완성하였습니다.
MarkAnthony
회원 가입일: 09/22/13
772 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 2,882
