소개
When everything is working as it should, the speaker produces nearly the same vibrations that the microphone originally recorded and encoded on a tape, CD or LP record.
필요한 것
Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
