소개
If the needle in your Crosley CR8005A is damaging your records, or not playing with the same quality it used to have, this guide will help you replace the needle.
First, make sure that the records are cleaned thoroughly to ensure that the skipping and damage is not being caused by dust and debris.
거의 끝나갑니다!
To reassemble your device, follow these steps in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
