주요 콘텐츠로 건너뛰기
Crosley CR8005A Volume Knob Replacement
필요한 것
  1. Crosley CR8005A Volume Knob Replacement, Volume Knob: 1 단계, 이미지 1/1
    • Identify the volume knob.
    • It is in the bottom-right corner of the turntable, just under the power light.
  2. Crosley CR8005A Volume Knob Replacement: 2 단계, 이미지 1/2 Crosley CR8005A Volume Knob Replacement: 2 단계, 이미지 2/2
    • Make sure that the power is off.
    • Turn the volume knob counterclockwise as far as possible.
    • Unplug the power cord.
    • The power light should be off. If the light is glowing red, wait until the light goes out.
  3. Crosley CR8005A Volume Knob Replacement: 3 단계, 이미지 1/1
    • Slip the plastic opening tool between the knob and the turntable.
    • In place of an opening tool, a spudger will also work.
  4. Crosley CR8005A Volume Knob Replacement: 4 단계, 이미지 1/2 Crosley CR8005A Volume Knob Replacement: 4 단계, 이미지 2/2
    • Use the opening tool to pry open the knob.
    • To prevent the knob from flying off, you can keep one hand lightly on top of the knob for security. There may be an audible click as the knob comes off.
  5. Crosley CR8005A Volume Knob Replacement: 5 단계, 이미지 1/1
    • The knob should now be free to inspect, customize, or replace.
결론
To put the knob back on, push the knob directly down onto its peg.
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Doan
회원 가입일: 10/30/19
204 평판
안내서 1개 작성함
University of Memphis, Team S2-G3, Kim Fall 2019 University of Memphis, Team S2-G3, Kim Fall 2019 회원
UM-KIM-F19S2G3
4 회원들
안내서 3개 작성하였습니다
댓글 2개
Hi, how to change the actual know (not the plastic cover)?
As mine is faulty and I could use some help please haha
Lucas Robin - 답글
Digi-key part # similar to PTD908-1215K-B203-ND.
Scott Whitehill - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 41
전체 시간: 1,962
