주요 콘텐츠로 건너뛰기
Crown Molding Trim Replacement
필요한 것
  1. Crown Molding Trim Replacement, Crown Molding Trim: 1 단계, 이미지 1/2 Crown Molding Trim Replacement, Crown Molding Trim: 1 단계, 이미지 2/2
    • Make careful slow cuts to avoid injury.
    • Cut around the seam of the crown molding with a knife or razor blade.
  2. Crown Molding Trim Replacement: 2 단계, 이미지 1/2 Crown Molding Trim Replacement: 2 단계, 이미지 2/2
    • Avoid prying too hard, which may cause damage to the wall or trim.
    • Gently pry the molding from the wall using a flat prying tool such as a putty knife.
    • It is important to take your time to prevent further damage to the molding or wall. This step may take several minutes to complete.
    • Work the putty knife back and further along the seams to gradually pry the molding from the wall.
  3. Crown Molding Trim Replacement: 3 단계, 이미지 1/2 Crown Molding Trim Replacement: 3 단계, 이미지 2/2
    • Remove old nails, caulk, or adhesives from the wall and/or molding.
  4. Crown Molding Trim Replacement: 4 단계, 이미지 1/3 Crown Molding Trim Replacement: 4 단계, 이미지 2/3 Crown Molding Trim Replacement: 4 단계, 이미지 3/3
    • Assess any damage to the crown molding.
  5. Crown Molding Trim Replacement: 5 단계, 이미지 1/1
    • Damage to this extent will likely be beyond repair. It will be better to replace that section of molding with new material.
  6. Crown Molding Trim Replacement: 6 단계, 이미지 1/3 Crown Molding Trim Replacement: 6 단계, 이미지 2/3 Crown Molding Trim Replacement: 6 단계, 이미지 3/3
    • Fill in holes created from nails with wood glue or adhesive.
  7. Crown Molding Trim Replacement: 7 단계, 이미지 1/3 Crown Molding Trim Replacement: 7 단계, 이미지 2/3 Crown Molding Trim Replacement: 7 단계, 이미지 3/3
    • Identify splits or cracks that are within the scope of repair.
    • If possible, place the nozzle underneath the split or crack and apply adhesive.
    • Remove any excess adhesive.
  8. Crown Molding Trim Replacement: 8 단계, 이미지 1/1
    • Apply rubber tip clamps to the repair area.
    • Read the instructions on the bottle of adhesive being used and know your product's cure time. Keep the clamp applied until the end of the cure time.
  9. Crown Molding Trim Replacement: 9 단계, 이미지 1/2 Crown Molding Trim Replacement: 9 단계, 이미지 2/2
    • Make measurements to prepare for the proper cut.
    • Make accurate measurements at the top and bottom of the molding since the length at the joints can vary.
  10. Crown Molding Trim Replacement: 10 단계, 이미지 1/2 Crown Molding Trim Replacement: 10 단계, 이미지 2/2
    • Use a pencil to mark your measurements.
  11. Crown Molding Trim Replacement: 11 단계, 이미지 1/1
    • Be careful when using a saw, as they can cause serious injury.
    • Use a saw to cut the trim.
    • A skill saw is recommended to get a clean, precise cut. A hand saw is doable and may be a cheaper alternative. If a hand saw is used, make sure it is specific for wood cutting to get smooth-edged cuts.
  12. Crown Molding Trim Replacement: 12 단계, 이미지 1/2 Crown Molding Trim Replacement: 12 단계, 이미지 2/2
    • Secure the molding to the wall using trim nails.
    • The nails need to be long enough to penetrate the molding and the wall. A nail gun is recommended, but a hammer and nail is a doable alternative. Nail placement is recommended for every one to two feet.
  13. Crown Molding Trim Replacement: 13 단계, 이미지 1/1
    • Caulk the seams of the trim to make a clean transition between wall, ceiling, and adjacent trim.
  14. Crown Molding Trim Replacement: 14 단계, 이미지 1/1
    • Smooth and remove excessive caulk.
    • Allow time for the caulk to cure. Once it is cured, the trim is ready to paint. Painting the trim will add a smoothness to the appearance and hide exposed nails or glue marks.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Merick Juarez
회원 가입일: 09/16/20
253 평판
안내서 1개 작성함
University of Memphis, Team S1-G10, Bishop Fall 2020 University of Memphis, Team S1-G10, Bishop Fall 2020 회원
UM-BISHOP-F20S1G10
1 회원
안내서 1개 작성하였습니다
댓글 2개
Hello Merrick Juarez
sir can you guide me on which glue I select from these all top 10 types of glue for furniture and Crown Molding Trim Replacement I have been read your all instructions but not clear about such glue which I use for the project. I have facing trouble in selecting the right glue for wood
Thomas - 답글
For a project like this, I suggest using any brand of wood glue. You can find these products at Home Depot, Lowes, or other similar stores. It does not matter which brand you buy. Just make sure the product is made for wood, and that you read the instructions on the product that you buy for the required cure times. I hope this helps.
Merick Juarez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 42
전체 시간: 1,541
