1. Flip your bike so the seat and handlebars are on the ground.
    • Flip your bike so the seat and handlebars are on the ground.
  2. Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
  5. Center the wheel and pull back to tighten the chain
    • Center the wheel and pull back to tighten the chain
  6. With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • Wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erin Heimburge
회원 가입일: 2013년 07월 11일
27 평판
안내서 1개 작성함
UC Santa Barbara, Team 2-1, Bradley Spring 2013 UC Santa Barbara, Team 2-1, Bradley Spring 2013 회원
UCSB-BRADLEY-S13S2G1
4 회원들
안내서 1개 작성하였습니다
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 61
전체 시간: 5,613
