주요 콘텐츠로 건너뛰기
Cruiser Bike Rear Wheel Replacement
필요한 것
  1. Cruiser Bike Rear Wheel Replacement, Rear Wheel: 1 단계, 이미지 1개 중 1개
    • Flip your bike so the seat and handlebars are on the ground.
    • This will make it easier to access tire.
  2. Cruiser Bike Rear Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel.
    • Handle the chain carefully to ensure a successful tire replacement.
  3. Cruiser Bike Rear Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Tighten brake strap using screwdriver and 10 mm socket wrench.
    • Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • You will know the socket wrench is has finished tightening when you feel resistance.
  4. Cruiser Bike Rear Wheel Replacement: 4 단계, 이미지 1개 중 1개
    • Center the wheel and pull back to tighten the chain.
    • If the bike wheel is unusable use tire levers to remove tire.
  5. Cruiser Bike Rear Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
    • Tighten the non-drive side (side without the chain) first.
    • The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
    • Use a tire pump to make sure the tire is full of air and ready to ride.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Erin Heimburge
회원 가입일: 07/11/13
36 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 11,624
