주요 콘텐츠로 건너뛰기
Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement
필요한 것
  1. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement, Recoil Starter: 1 단계, 이미지 1/1
    • Remove the four screws from the hood of the lawnmower using a Phillips #0 screwdriver.
  2. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 2 단계, 이미지 1/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 2 단계, 이미지 2/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 2 단계, 이미지 3/3
    • Remove the hood of the lawnmower by pulling up.
  3. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 3 단계, 이미지 1/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 3 단계, 이미지 2/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 3 단계, 이미지 3/3
    • Using a wrench, remove the three nuts from the lawnmower’s defective recoil starter.
  4. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 4 단계, 이미지 1/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 4 단계, 이미지 2/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 4 단계, 이미지 3/3
    • Remove the defective recoil starter by pulling up.
  5. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 5 단계, 이미지 1/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 5 단계, 이미지 2/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 5 단계, 이미지 3/3
    • Place the new recoil starter in the lawnmower where the defective one was prior.
  6. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 6 단계, 이미지 1/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 6 단계, 이미지 2/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 6 단계, 이미지 3/3
    • Tighten the new recoil starter onto the lawnmower with a wrench and the nuts you had removed earlier.
  7. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 7 단계, 이미지 1/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 7 단계, 이미지 2/3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: 7 단계, 이미지 3/3
    • Tighten the hood back onto the lawnmower with a Phillips #0 screwdriver and the four screws you had removed previously.
    • Make sure not to screw the hood on too tightly.
결승점
Andres Dominguez
회원 가입일: 01/26/22
145 평판
안내서 1개 작성함
CSU Los Angeles, Team Z-69, Briggs Spring 2022 CSU Los Angeles, Team Z-69, Briggs Spring 2022 회원
CSULA-BRIGGS-S22SZG69
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 128
전체 시간: 1,808
