주요 콘텐츠로 건너뛰기
Cuisinart CHW-12 Power Cord Replacement
필요한 것
  1. Cuisinart CHW-12 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 Cuisinart CHW-12 Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Power Cord Replacement: 2 단계, 이미지 1/2 Cuisinart CHW-12 Power Cord Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Power Cord Replacement: 3 단계, 이미지 1/3 Cuisinart CHW-12 Power Cord Replacement: 3 단계, 이미지 2/3 Cuisinart CHW-12 Power Cord Replacement: 3 단계, 이미지 3/3
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Cuisinart CHW-12 Power Cord Replacement: 4 단계, 이미지 1/3 Cuisinart CHW-12 Power Cord Replacement: 4 단계, 이미지 2/3 Cuisinart CHW-12 Power Cord Replacement: 4 단계, 이미지 3/3
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  5. Cuisinart CHW-12 Power Cord Replacement: 5 단계, 이미지 1/3 Cuisinart CHW-12 Power Cord Replacement: 5 단계, 이미지 2/3 Cuisinart CHW-12 Power Cord Replacement: 5 단계, 이미지 3/3
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  6. Cuisinart CHW-12 Power Cord Replacement: 6 단계, 이미지 1/2 Cuisinart CHW-12 Power Cord Replacement: 6 단계, 이미지 2/2
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
  7. Cuisinart CHW-12 Power Cord Replacement: 7 단계, 이미지 1/3 Cuisinart CHW-12 Power Cord Replacement: 7 단계, 이미지 2/3 Cuisinart CHW-12 Power Cord Replacement: 7 단계, 이미지 3/3
    • Pull the circuit board out of the containment box.
    • Locate the power cable connection point on the circuit board.
    • Desolder the power cable wires connected to the board.
    • Solder iron can cause burns if used improperly.
    • Replace the power cable with the corresponding wires of the new power cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Trevor Aspinall
회원 가입일: 03/22/18
359 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S17-G2, Blackburne Spring 2018 Sam Houston State, Team S17-G2, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 1,847
