주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Turn the device upside down. Remove all four rubber feet by prying them out using the metal spudger. Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Remove the base from the body of the blender. Remove the base from the body of the blender.
    • Remove the base from the body of the blender.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver. Gently move the wire aside so that it is not in the way. Gently move the wire aside so that it is not in the way.
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  5. Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
  6. Cut the zip tie that holds the black, blue, red, and yellow wires together. Take care not to cut the wires.
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
결론
다른 2명이 해당 안내서를 완성하였습니다.
William Hesse
회원 가입일: 2018년 09월 24일
436 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 116
